Help Minor update on Nexus 4 issue
MarmiteX1
Hi there,
I've read posts online about a new 4.3 update/patch for Nexus devices being pushed out.
I got mine this morning via OTA. When i tried to update it via OTA, it went into CWM recovery and attempted to flash it. I then got the error "Installation Aborted.... Status 7" error in clockworkmod recovery.
I rebooted my phone and it tried to optimise the apps. But whenever i go to about phone the build number is still on JWR66V instead of JWR66Y:mad:. I then tried to update it again via OTA but it says along the lines of "No new updates".
I decided to flash the OTA zip file via CWM by getting the file from this website:Download: Android 4.3 “JWR66Y” OTA Updates Roll Out (Nexus 4, 7, 10, and Galaxy Nexus) – Droid Life
The same issue occurs. It keeps failing. The CWM recovery version is 6.0.3.4. I still dont see the OTA update anymore from Google.
What should i do? Any ideas please?
****UPDATE****
I got round this by following these steps(in my case):
- Ensure that you have the latest SuperSu zip file on your internal storage
- unroot through app e.g SuperSu
- boot into recovery
- flash required updates
- while still in recovery, flash SuperSU zip file
- reboot(if it asks you to disable flash recovery, select YES!)
- After reboot, grant all apps which require su root access again
My Nexus 4 is still unrooted, but I had rooted my Nexus 7 just a day before the update and this worked perfectly. Cheers! :)
You need to be on the .84 stock radio, stock kernel, no modifications to the system file & all system apks installed for the JWR66Y update to execute. If you have done any of the lte mods which alter the build prop & flashed one of the hybrid radios you need to revert these changes first to update. I used a nandroid backup made after updating to JWR66V which is not altered & flashed update in found in link below via cwm recovery.
http://forum.xda-developers.com/showthread.php?t=2145848
