Root Mirage or Backside?
Time to gauge the pulse I guess...been running Backside for 2 and a half weeks now...
However, I'd like to know what Mirage can do for me that Backside can't from an overall perspective. Essentially pros and cons to flashing Mirage?
No pros, no cons. Not gonna say anything, as I don't like to compare roms.
Mirage has the best battery life atm I believe. MRG made a solid kernel.
Well... backside has more custom theme options built into the rom and is rock solid. Development on it seems to have stopped and the kernel included dosent support the zv9 radio (easy fix just flash a new kernel) mirrage rom is rock solid and mrg is actively updating adding performance tweaks as well as icon/theme changes. It has zv9 support standard. Don't forget there are other IHO roms that are excellent choices as well. The best thing you can do is try out several and see what works best for you. Its a big part if the fun of being rooted
