I am fairly new to the realm of working with my phone in an extended uses. I am trying to file transfer through a IRC. I need to forward ports 10000 thru 10070. Can anyone help with this problem.
I'm going out on a limb because no one's answered you yet (unusual for this forum!) - so - isn't that port-forwarding requirement somewhat dependent on the IRC client you're using?
I'm only asking because I've come across a _lot_ of users that swear by Trillian and that claims to support file transfer in a straightforward manner:
Yes it is an mIRC, it is actually Karaoke Realm,(sorry didn't want look like a complete NERD). They do ask that you forward the range of ports, which is really no problem for most "usual" routers but we are dealing with SP___T. I would imagine if I could forward any one in the range it would be fine.
I do not know if this helps but I am using Filelinx to transfer files from phone to PC and back. It's on the Market. It is pretty easy and works in a LAN or from anywhere.
Transfers any type of file.
I am not 100% sure what you are searching for but maybe "Port Forwarder" https://market.android.com/details?id=at.bherbst.net does what you need. This app was intended to forward a single port to a host. Such host usually resides in a subnet that you created using some kind of Tethering (USB or Wifi). However, this Port Forwarder may also be used to forward to localhost and therefore reroute to a different port on your device. Does that fit your needs?
