Help Missed Call/Message Notification
Kamau
Android Expert
Does anyone know of an app that let's you know when you've missed a call or text, while the phone is charging? My led blinks when off the charger, but does not while on it. It only shows red when it's charging, and green when the battery is full.
I'd like something that would either override the led, or wake the screen to show a missed call or message.
I've had great success, and still use it, is Missed Call Reminder:
https://play.google.com/store/apps/...sImlkdi53YW5neWlrLk1pc3NlZENhbGxSZW1pbmRlciJd
It will keep repeating for missed calls, texts etc
Try it:)
Correct.
When I'm at home, my phone stays plugged in 99% of the time. I would like something that would tell me just at a glance if I've had a call or message.
Correct.
Haven't used this app, but it's worth a try.
https://play.google.com/store/apps/...29uc3VsdGluZy5hbmRyb2lkLmxpZ2h0Zmxvd2xpdGUiXQ..
In the description, it says HTC phones usually require root, so I'm not sure if it will work if you are not rooted. :)
Here is another one I found:
https://play.google.com/store/apps/...29tLnRvbWF0b3gubWlzc2VkbWVzc2FnZWZsYXNoZXIiXQ..
And another with some good reviews:
https://play.google.com/store/apps/...iY29tLm1vbmtleXNwYW5uZXJlZC5mbGFzaG5vdGlmeSJd
Thanks, I'll give them the a great, but I see am not rooted. It may or may not work. But the fact not, nothing lost.
