Missing Album Art
New to the site so not sure if I'm posting this in the right place but sure someone will correct me if not.
Just switched from iPhone/iTunes to DHD and have loaded PowerAmp which I luv with the extra controlability and the quality of the output. Used 'itunes agent' to move playlists across which all went really well but downside is that not all of my album art has uploaded so there's a fair few gaps I'd like to fill.
Any suggestions on an easy way to do this would be much appreciated.
Cheers
BTD
Cheers
BTD
This is nice and easy with Power Amp. When you go to an album that has missing album art, select a track and press and hold where the art would be, power amp will then search for album art for you, select the one that is appropriate, job done :)
