Root Missing clear command
Bee1
Installed cygwin, missing clear command for kitchen, can't get ncurses to "skip " to another installion in download
clicked on everything, get source,install, uninstall,keep,check box,unckeck box.Click on what exactly?
click on the word "skip" and it will show you a version. click again on the version for an older version. click again and it goes back to skip
D**n, get pass one hurdle now there is another...same sh*t only this time it is Lib to termifo...no skip. Last time I uninstall to get skip
P.S. I only uninstall ncurses then reinstall.I am going to stay with cygwin and kitchen though
Id still recommend going through and trying to do a clean uninstall of cygwin first then go back and install it again. You can save all your kitchen files and stuff then just drop it back into cygwin after
