Missing icon on my home screen..
Hi there
When I first got my X10 mini pro on the home screen in the bttom rght hand corner I have got my phone book, bottom left its a square icon that show's my call log, top left if messages (sms) icon and in the top right it was music icon that is now gone missing - how do I get it back? I must have deleted in error while getting to know my new phone.
Edit fixed it - thread can be closed thanks!
You should find in the missing app in amongst your normal apps.
While the app icon is visible, click and hold the app. The background of the screen will change (black usually) and the corner icons will appear. Drag the icon to the corner and release.
PS: You can use this to put any app icon in any corner. I have an audio recording app instead of the music app (since I never use it) on mine.
Hope this helps.
