Using app 2 sd pro, the apps run but the icon is just a blue default icon for all apps that are on the card or in the media area. If I move it back to the phone, the icon reappears.
Try this ... move the app back to the phone, then go to menu>settings>applications>manage applications (if you are on Gingerbread) and select the app you want to move. You should see a "move to sd" button and see if that retains the logos on screen.
That is essentially what I have been doing, as using the "app to sd pro" app just takes me directly to the same screen as you led me to. So I don't think I am moving the apps any differently.
