Help missing icon
jgriner
Member
one of my icons is missing, when i press the button that list all my programs, its not there.
its listed under manage applications.
when i go to the market is shown as installed, its the only way i can launch the game!
did you move or install it to the SD card?
if so move it back then see if the shortcut is there. then move it back, I've had this happen.
thanks guys, that is excatly what happened, do some apps auto install on sd card?
I've noticed that there are some apps that will install on my sdcard rather than internal storage. There are very few but I do think that there are some.
