Missing Icons
Bought the Sprint Tab on Fri, & am really liking it! That being said, every time I power it back on if I turn it off, my Dolphin HD icon & Angry Birds icon disappeares from my home screen & I have to add them on again. Not really a big deal, but does anyone else see missing icons when powering on their Tab?
Not sure whats going on. Try loading LauncherPro and Home Switcher. Once you load both go to the app drawer and choose Home Switcher and then choose to launch LauncherPro. You can make it the default if you want. Add the shortcuts you want and then reboot. See if your shortcuts stay. If they do, you might have an issue with the Samsung interface. I would recomend wiping the device back to factory if this is the case. Just something to try.
I also have this probem: icons for any apps stored on the internal SD card do not get displayed on the homescreen after reboot. Any suggestions for a workaround for this? (apart from moving said apps to "phone". Actually, I come from HTC phones so the idea of internal SD is new to me. When you move an app to SD card, does this let you choose which SD card on the Tab?)
