Help Missing pre loaded 3d pictures (link inside)
D
Deleted User
Guest
I went to show off the phone using the stock photos and they were nowhere to be found. Please any ideas?
Along the lines of the camera functions...
How do you delete a pic you just took?? I can only seem to do it from the gallery, please tell me I don't have to go to the gallery in order to delete a picture.
did you format your sd card? or put a new one in?
thats the fast way...the other way is to use a file explorer...please enlighten us as to what would be a better way....
Yes I formatted it in order to bring my contacts over from my old phone :(
well thats the reason you dont have them. you dont even have the green hornet video do you?
or did you copy them over, format and then tried to reinstall the copied 3D pic folder and now you cant access them?
I reformatted. And mounted it thinking that the pics were stored on the internal memory not the sd card. I do still have the green Hornet. Is there any way to recover these or download them from htcs website? Or are they gone forever never to return?
I can upload a zip for you when I get home...my office firewall blocks dropbox..
out of curiousity, why would you need to format the sd card to bring your contacts over?
any Sprint retail store has a celebrite device that connects both phones at the same time and copies them all over plus any photo's you may of had also.
just wondering why you needed to format the card
You sir or mam are a scholar and a saint. The thank you so very much.
I didn't want to have to take it to my sprint store which is a good 25 minute drive depending on traffic. It was a lost cause anyway because I did it via bluetooth. And I reformatted because it said I needed too.
makes sense, glad to see someone can get them to you.
I don't blame you for not wanting to drive, where I am everything is a good 25-30mins away.
Yeah I have 3 verizon stores all within a 10 to 15 minute drive of me but the only sprint store is 10 galaxies away. The really pretty annoying.
