I am having the same problem and I have done all of the above and it still says desktop not found. I have been able to sync in the past, but after upgrading both phone and macbook to missing sync 1.4.2 I have not been able to. I have airport extreme and my ip address on the airport is 10.0.1.5, and the eris says 10.0.1.200. should those be the same? I am not sure. can anyone give me some help.Hey,
First, be sure to turn off any firewall on your PC (and try to sync again if there is one) also... look in the Help section of Missing Sync on the PC, there is a 'Fix Connection' button. Go ahead and try to select that and also try to sync again as that restarts all the Missing Sync background processes.
If still not syncing,
1. On your device, Unpair with the desktop (in Missing Sync)...if you are paired
2. Reboot your device
3. Reboot your desktop
4. Verify both device and desktop connected to the WiFi router and you have internet access (can browse the web)On the device, also check this: Settings>Wifi>Wireless Controls> Wifi.
5. Run the Setup Assistant, in Missing Sync on the desktop and it will generate a PassKey
6. Launch Missing Sync on the phone and enter this passkey, and hit the 'Pair' button
7. Now try to sync... Contacts and Calendar syncing are initiated on the phone and synced wirelessly (WiFi or Bluetooth) and not over USB .. Media syncs using the USB cable and its initiated on the desktop.
