Help Missing Vibration ? ... give it a tap!
:-( sorry to hear that .. I guess mine was fixed when the swopped the motherboard . Hope thesort it this time for you .
Cheers tef89. I got it back again yesterday with the same problem. Looks as though Vodafone haven't even returned it to HTC this time and just re-installed the software :mad:
I've got an Orange San Fran as a backup so not missing it too much. Determined to get the problem sorted though.
So far so good, although it looks as though the replacement is SLCD. I'd rather have that than a broken vibrate mind.
Not sure if it's of help for others but it may have been caused by swype. At the time I was typing something and it seemed to 'freak out' half way through. The vibrate appeared to go crazy for a second then died. May not be the cause but a thought anyway.
Hi mhammadw, and welcome to AF :)
Which of the different solutions in this thread do you mean? Tapping the phone, playing with audiomanager settings or sending it for repair?
Tthe etiquette of a discussion forum is that solutions are posted publically to the forum, so that others can benefit, rather than communicated by private mail.
In any case, your best bet is to ask in the Desire C forum.
Good luck!
I found out how to get ur vibrate back!! If ur power saving mode is on u will have no vibrate... If that doesn't work try restarting ur phone
