missing wallpaper
amagalla
I'm using a wallpaper that came with the phone that I really like (water on a black surface). The problem is that since the upgrade to 2.3.4, that wallpaper is no longer in either the wallpaper gallery, or the wallpapers. Weird thing is that it's still set as the current wallpaper. Now I'm afraid to change away from it because I don't know if I'll be able to go back to it. Any idea where in the file system the current wall paper is stored, or how I can save it?
Thanks.
Tony
It appears that this wallpaper was removed in this update. If you change it you will lose it (happened to me). Go to this thread to get it back and add it to your Gallery (you may have to reboot for it to show up). You can add wallpaper from your Gallery. When you do, it will show you a crop box. Make sure you expand it to the full size of the image.
https://supportforums.motorola.com/thread/54769?tstart=0
