e1978mustang91
My htc thunderbolt doesnt make any sounds whne unlocked and the thunderstorm rolls in. How do I change this?? thank you!
Its easy on your home screen, if you have the HTC Weather widget, click on the Weather (not the clock) as this will load the Weather app, then press the menu button, select Settings and check the box for "Sound Effects" and that's it. hopefully this is what you wanted.
BeZeRk
