deanshep85
Android Expert
Well I finally took the plunge and downloaded MIUI and so far so good..
had major FC issues but a wipe and reboot helped...then I screwed my a2sd up, so had to reinstall that then rewipe etc..
BUT all that sorted...titanium backup doesnt wanna install half my apps *BUT* that I can overlook...
but notification lights and sms (default miui one) notifications not working at all?
anyone else have this issue?
I dont really wanna install another program to deal with LED notifications if it SHOULD be there by default..and I dont really wanna have to flash my nandroid of GV back again as I was having calling issues sadly with it..
And pleeeeeeease someone don't suggest look at the XDA thread...I tried...and failed...just tooooooooooo many pages..and my search wasn't working very well or at all
so yea..anyone using this version of MIUI and if so do your notification lights work? and does the default sms notification work?
also...any got the MIUI blacklist app working? everytime I try putting a UK number in it always puts (00) in front of it, which is not a UK dialling code...im wondering if this is unfortunately not for us brits..
