Root MIUI and MMS
JLO73
I flashed to MIUI 1.2.11 on my incredible. This is my first flash. Had a minor problem getting into v/m but that issue is resolved.
My issued now is sending and receiving MMS. I cannot do either. When I try to send a pic it doesn't freeze but never goes through. When I receive I get the download button and when pressed it acts like it is downloading but never does. I have checked the auto retrieve setting and have a strong signal. What am I doing wrong or is this a common issue. Did a search and could not find anything.
miui has it's own forum where bugs and fixes are posted:
http://www.miui-dev.com/forums/forumdisplay.php?19-HTC-Incredible
Or use the forum app on the phone.
I'm currently on miui but have not experienced that issue. I'm using 1.28.11 and haven't updated since I have zero bugs with this version. Only thing I can reccommend is to flash to that version or try reflashing the version you are on after doing a full wipe.
Also seems like you'll have issues if you installed the rom using clockwork 3.0.0.5, you need to use a 2.*.*.* version.
