Root MIUI Battery Charging Problem
Hi guys, me again!
So my experience with MIUI is going quite well so far. One or two tiny bugs but overall quite good.
But one which is bugging me is a charging problem.
When I charge it, it charges to 90% then the LED goes green and charges no higher.
I have done the battery calibration technique it recommends and the phone charges to 100% when it is turned off. It just only charges to 90% when it is powered on.
Does anyone else using MIUI (GingerBread build) have this problem and does anyone know a fix?
Thanks
Green LED at 90% charge is normal. Its not a bug. Happened in both Gingervillian and MIUI-XJ but it keep on charging till 100%. So just leave it there for sometime and check.
