SHO_ONE
I absolutely take no credit for this rom what’s so ever! I am, like most of us phandroidian's, a rom`aholic and have an overwhelming need to share what I have found to enjoy.
I started a thread for Cyanogenmod7 and hoped it would take off as at the time there was virtually no where for a rooted user to go and simply discuss CM7 and all of its goodness... that is, no where to go for an EVO user that is... With that same sprit in mind, I've ventured off to the MIUI Rom and am enjoying it; however I've run into am issue and it would seem in my digital travels so have some of you... I hope this thread will grow as my other thread and we can get the awesome phandroid community together to solve the issues that arise in the MIUI Rom.
The current MIUI Rom is 1.5.13 found at
http://forums.miui.us/showthread.php?5-MIUI-Evo-Release-Thread-1.5.13-Chinese-amp-English should go into a bit more detail as to what this version entails and so on.
There is no 4G as this a variation of an ASOP version of Android with an iphone`esk feel. Don’t be fooled, this is not an iphone skin nor is it by any means the iphone OS. This is a merger of the two and quite frankly what the iphone hoped to be, but could never amount too.... With that said, I am not a fan boy of any one system, but a lover of technology and don't proclaim anyone one piece of tech better than another.... simply because!
Moving on...
I have found that with previous versions, Google voice worked without issues; however Google Voice seems to be experience FC's with 1.5.6, latest talks are 1.5.10 has a fix, but I haven't seen anything yet. I attempted a fix for Visual Voicemail through sprints VVM and I'll have to link this to my CM7 thread..... This is a supposed fix for Sprint VVM that’s supposed to work for MIUI and CM7...
1) Select your phone icon and press menu > select DND Mode
2) Then disable "Show Notification" and "Anti-stringer mode" at the bottom
3) Then select "Reject from blacklist" and then click the arrow on the right
4) Then select "Don't intercept calls" and "Silence notifications"
5) Then go back to the top and select "Blacklist members"
6) Add 9016 and you should be set
Or
1. Download VVM and update from XDA here (CM6 ADVICE,TRICKS,APPS(added market and kernels) - xda-developers)
2. Moved to SD
3. Navigated to the apk via Root Explorer, clicked, installed
4. Sent blank vm to activate@vvm.sprint.com
5. Dialed *38 (rings three times and hangs up). I was using Google Voice while running CM7, so this turned Sprint back on.
6. Be sure under settings->call settings->voicemail service is set to "My Carrier"
Hope some of that helps. I'm new to all this
Or
Go here for the Titanium Back up Method... which again should work for CM7 and or MIUI... http://romrepo.info/wiki/index.php?title=Install_Sprint_Visual_Voicemail
Again, I take no credit for the Rom or fixes. What I have done is the research and posted what I could for those of you in need! I too will be attempting the fixes and will post my findings once I have something to post.. Till then... please do so as well!
*****EDIT / UPDATE****
What I did was a combo of things here... I did the TB fix listed here and other sites (google is our freind) then remembered that I too used Google Voice and never deactivated it by dialing *38 <- do this!!!! My Sprint VVM works flawlessly - - - - Solved!
Moving on...
Or
2. Moved to SD
Or
