Root MIUI hard resetting on each reboot
BimmerM3
Member
I had MIUI 1.10.7 when my phone suddenly shut off and rebooted. Reboot took way longer than normal and when it finally finished I found my phone apparently updated to 1.10.8 and wiped. Tried several reboots and the phone hard resets everytime. I never expected this from a rom like MIUI.
1.10.8?
A new build comes out every week so valid versions would be 1.10.7, 1.10.14, 1.10.21, 1.10.28 (which was pulled).
Do you have a recovery backup you can restore? I back mine up at least every time I upgrade a rom. It's saved my butt too. Today I nearly had to sbf and my backup was only 2 days old. :D
Well, .28 is a bad build that was pulled. 3g tends to disconnect and if you try to change your settings for it you could end up with FC hell. (Ask how I know.) :D
You could reflash .21 or there's should be a new build out any time now (probably the last one): MIUI.us UNITED WORLDWIDE - ROM Downloads
Sorry, without a backup in recovery OR a Titanium backup, there's not much you can do except complain.
