Root MIUI loaded
Now I can't get gingerbreak to run and hence can't acces titanium backup. Any idears?
Okay after you install titanium backup and you run it for the first time it will give you problems. To fix this press your settings button while still in the app and scroll through the menu till you find reload and then choose that. It should fix the issue at hand
I did a fresh flash to the latest MIUI build and had issues with TB. It was claiming no root, as was Busybox. Turning on root permissions in superuser didn't help. I checked, and I had root, but the apps said I didn't. I restored a backup from a while back and flashed over it, and it worked fine.
as I stated in my pm agent. for some reason my TB and busybox said the same thing. Now they are working great. Not sure what the problem was but I didn't do anything to fix it.
