MusicJunkie
Android Expert
Is there a way to decrease the size of the icons in either MIUI ROM without decreasing the density? Lowering the density messes with one of my apps and causes it to not function well or at all. Thanks!
Any of the typical tweaks will work. CoD, v6 supercharger, smurfed out, ect.
As far as the icon size, as I said in PM i haven't found anything that wont bork your apps
As far as ease of use smurfed out its probably the easiest. I'm not sure if he got rid of the toggle issues or not though.
It will make your phone absolutely fly![]()
If it doesn't work out, unsmurfing provides you with some laughs at least
Question, I can I "multiple smurf" after the reboot? Or no? O_O I did the I/O scheduler first and I was wondering if I can do any other smurfing without screwing anything up.
