Root MIUI Rom trouble
Im currently using the latest MIUI rom and have notice that the vibrate for text and or calls does not work.. anyone have any way of fixing this??
Check in the settings for haptic feedback, and check it. This is what gives you the vibration.
If that doesn't work, try to wipe the cache and dalvik cache, and see if that works.
currently running all stock apps on MIUI and how exactly do i navigate to the haptic feedback?
update: while looking for the patic feedback i saw a section about vibrate in the settings that i have missed and turned on the vibrations thank you folks for the quick response you all are awesome
