jjohn7293 Android Enthusiast Dec 24, 2012 #1 OK is there any way at all to get MMS working on the ROM? It is based on sense 3.6, so there should be a way right???
johnvansavage Member Dec 24, 2012 #2 i believe this guide should work, i think thats how i had it working, if not try see if you can manually enter the vm apns mmsc="http://mmsc.vmobl.com:8088/mms?" mmsproxy = "205.239.233.136" mmsport = "81"
H heythereitsv Well-Known Member Dec 24, 2012 #3 johnvansavage said: i believe this guide should work, i think thats how i had it working, if not try see if you can manually enter the vm apns mmsc="http://mmsc.vmobl.com:8088/mms?" mmsproxy = "205.239.233.136" mmsport = "81" Click to expand... It doesn't. Xiaomi seems to have made enough changes to the base that it doesn't handle MMS the way Sense does- it handles it like AOSP does.
X xkravenx Member Dec 27, 2012 #4 jjohn7293 said: OK is there any way at all to get MMS working on the ROM? It is based on sense 3.6, so there should be a way right??? Click to expand... I am waiting gor MUIU too. Need --> 4G and MMS.
jjohn7293 Android Enthusiast Dec 28, 2012 #5 xkravenx said: I am waiting gor MUIU too. Need --> 4G and MMS. Click to expand... You shouldn't have i to wait too long. It seems to be coming along nicely... Although i have seen like 3different threads
rodgman15 Well-Known Member Dec 30, 2012 #6 If I could get my hands on MIUI with 3d and MMS i'd be a happy camper, unfortunately there's no 4g where i'm at .
