Carbonatic
Member
Hey Guys In Many Thanks To @Curtis1973 For Making The Rom Port Guide I Am In Progress Of Porting Miui V6 For Lg G2 to Lg Volt Will Post As Soon As im Done Fixing Anything That is Needed To Get Fixed And I Hope U Guys Enjoy
Hey Im having Issues Of Error Executing updater Binary When i Flash Is Their A Way To Fix Thatxperia m2 is a match but slim pickings there
Thanks Will Let U Know When DoneI'll test for you... BTW look at l90 or g2 mini.. They are closest
I Tried Uploading But Site Wont Let Me And i Just Decided To Rebuild Now With Lg G2 Mini Editon Instead Of Miui Hopefully it Worksthe original unedited ones of both ROMs your using.
Im Having Issues To Boot Stuck On Boot Loop I Still Dont Know How to Use ADB And Im On Windows Any Help Will Be Appreciatedthe original unedited ones of both ROMs your using.
http://forum.xda-developers.com/android/software/guide-build-port-miui-rom-to-device-t3250984Lattest Update Now Its Been Official Miui Is Not V6 Anymore Updated To V7 Instead
Need help rebuilding ramdisk back together and rebuilding boot IMG I don't have Ubuntu using windows for all the work any help aprriciated @SykkNyzz thanks for the guide that was the one I was using when I started with v7 but I need help rebuilding ramdisk and boot IMG I had an issue with it not working boot error as soon as I got to lg logo I got some errors at the toptried getting the miui v7 from lg l90 ported. can get boot animation going... that's about it. not sure if permissions are sticking like they should...but I did notice the miui I tried to port was already a port from another device to the l90....I bet that's where the issues are. on to find another device with complete original build.
U Think I Could Get A Copy Of That One Then To See If Their Is Anything I Can Do To Help With Getting Data And Probably To See If Is Possible I Can Also Try Updating It To Version 7 With The One I Have Built That Is Stuck On Boot Looptom1957 has miui v5 running. no data. been working with his version but still can't get data working. will keep plugging away at it. but doesn't look good.
Ah Ok I See Thanks @Curtis1973I've got the ROM. but will need to get toms permission to share it so others can help fix it. version 5 does not require boot image hacking...that's why v7 won't boot for us.
