Xruptor
Hey folks I found a working version of MIUICamera that works flawlessly with CTMOD and CM7 mod.
The previous versions had issues where if you clicked on Color Effects it would force close the application. This version however works perfectly and the color effects options works as well.
MiuiCamera.zip
For those of you that want to install it using CW5. I have use ApkInstaller and put it together already for you.
Download this one if you want to install using CW5.
http://www.mediafire.com/?0kzmdvym7f22adi
Enjoy!
MiuiCamera.zip
Enjoy!
It was driving me nuts.
