Help MLB At Bat 11
What is the problem with my Moto Droid X that it will not play audio of MLB At Bat 11 without cutting out 4-5 times per half inning?
I activated my old HTC Eris and it works fine NO CUTTING OUT AT ALL.
What is different in the Eris that will allow audio to play better than the X?
Go into the settings and then for audio feed try the alternate audio feed.
Yep. Tried that. No difference.
Tried wifi on----no difference
Tried wifi off---no difference
The Eris will only not work in places where there is no cell reception what so ever. West Virginia Turnpike (aka-CELL HELL)
X can have full 3G reception and cut out multiple times per half inning.
I don't seem to have that problem on wifi. Have you emailed them about it?
I have it cut out once in a great while, especially when 3G signal is weak (my mom's house), but I don't visit that often (bad son!). Other than that, it's pretty good. Of course, it will only cut out when there is an exciting play and they are just about to score, get tagged out at the plate, turn a triple play...you know, the usual plays!!!!;)
Seriously though, try rebooting and/or uninstall and reinstall the app.
I have the same issue on my Droid X. 3G and Wifi. Android 2.2 and 2.3. MLB At-Bat 2010 and 2011. Audio drops constantly. Both feeds.
I use the at bat app almost every day during the season. I'm streaming audio or video at least 2 or 3 games a week. I never had any problems with it until some recent update. Whenever they updated it to where you can hit the switch audio feeds from the audio feed screen, I've had nothing but problems. I have perfectly good signal and traveling in the same places I have before the update. It's almost unusable to the point where it drops out 3 or 4 times every half inning. The good news is the season is almost over so I don't have to endure it too much longer.
