Fuzzy13
Extreme Android User
I'm modding part of a mms app (black bean stock mms) just for personal use and learning code per say. It's one of few that still utilizes the quick reply "pop up" and it's also customizable.
The standard quick reply pop up looks similar to this
I've changed some things around to make mine look similar to this without the 3 dot menu button.
I've added a small image to the top right corner to act like the "view" button from the original pop up which opens up the current conversation. Even though I've added the android:id associated with the "view button", the button doesn't do anything.
The quick reply pop up is split into 2 xml files. The view and close buttons, text slider and divider for the buttons are in one file and everything else within the pop up "box" is in another. In the xml containing the buttons, I just changed all the values so nothing in that xml would show up because it wasn't needed to achieve the newer design I wanted.
So I'm trying to find out why my new button isn't opening the "view" even though the layout is written correctly and has the correct android:id. Is it because the id is in the other xml from where the new code is written? I know the code is correct because I added an id from the same xml I'm using the new code in like the "send" id and it worked prefect.
Now here's the thing. I added my new code for the new button to the xml that originally contained the "view" button and my new button worked perfect. But I can't get the image to the right location. It's either in a new line above everything or a new line below everything.
I've tried everything I know to and I'm close to giving up. I really need some advice.
If you can't tell my xml knowledge is limited. I've learned by trial and error so please be patient with me. If anyone can offer any help or advice I would be greatly appreciative.
