Root MMS.apk
I'm gonna go on and guess MMS.apk is a system app. Don't remove system apps.
Well it is, so here's the problem I am having, every time I launch messaging, it prompts me to use GoSMS, or Messaging, and I tell it to use GoSMS, and check the box that says default, but after a reboot, it does it again.
I don't know how to fix that. Try clearing defaults on GOSMS after setting it as defualt, then reset it as default, then reboot. I can only suggest ideas.
sometimes it breaks multimedia messaging. however, text will always work.
But proceed with caution. I did this with the intercep and even though i did a restore and put stock back on it permanently took photos and video sideways and there is no fix. I'd be livid if i did that to a 300 phone. Please post your usage and uploading findings if you decide to risk it :)
