Help MMS Auto Retrieve?...
jtb199
I was trying out gosms and noticed that it would not download MMS automatically...
I have auto retrieve in the stock messaging app checked...
I use and have always used handcent for all messaging but was wondering why gosms would not work properly...
So I tried to send a test mms to myself from the stock message app...still will not download automatically...just a download or decline option...
But...I can force close the stock messaging app...send a test MMS and it works...it opens automatically...but that's it...I can try again and same thing...just a download or decline button...
I have been on the phone with HTC and Verizon...neither had any idea what is causing this...
So I did a factory reset today...and without installing any other apps...thinking there may be some kind of conflict...but still have same the problem...
Is there anything else I could try?...any other ideas on whats going on?...
Thanks...
Don't know the answer then, never used that app. Sorry
Thanks for the reply...
I did notice under settings that there is not "auto retrieve while roaming" option...
That may be the where the problem is?...
Since I am in extended network?...
