mms download problems
My Samsung Infuse 4G will not download/opn MMS messages
don't know what "rooting" is...I am just a basic human trying to get a picture from a client on my phone. Yes I am connected to wi-fi at home and yes I have the packet data enabled. just will NOT open...says "downloading" and when I click on the msg it gives me (useless) "msg details":confused:
Are you using the stock messaging application (the one that came on the phone)? Or are you using a replacement app (like Handcent or GoSMS) ?
I've gotten this multiple times on my G1 and Infuse across multiple ROMs and Android versions. I don't know if it's an Android problem or a carrier issue... maybe a corrupted picture file gets sent.
I have the same issue this is what i do, "its a pain"
ok you get a notification of a message, WAIT, bout a min, then you "should get another sound vib" that means message is complete.
sometimes i dunno why if you open the message before the pic is fully sent to you it hangs!
not saying this will work for you its just my experiance!
