Mancow60
Ok so maybe some of you have noticed that you can't send MMS on 3rd party SMS apps. I used to use Go sms, Textra and now use 8sms and none worked so had to use default messaging app to send MMS. After much research and messing with phone I found a fix! We need to manually input APN information.
These are instructions to 8sms app, but should be about the same for other apps.
Open 8sms, go to Settings>MMSC settings. You are going to have to type this inside the following sections.
MMSC: http://mmsc.vmobl.com:8088
MMS Proxy: 68.28.31.2
MMS Port: 80
Please let me know if it works for you.
MMS Port: 80
