Root MMS Force Close - Skyraider 3.0 RC3 Vanilla
LaCeS OuT
Member
I have Skyraider 3.0 RC3 Vanilla installed on my Dinc. I always get force close when trying to send MMS. I had tried attaching from MMS, sharing from Gallery, even sharing from Web Sites. Always get an FC when trying to send. For those that actually send rarely, the person doesn't receive anything. No pic or text. Is there a fix for this? Love the ROM but if I cant send MMS I have to switch. Don't want to use Chomp or Handsent. I like the stock app.
Two things I'd try:
1. Go into clockwork recovery and wipe cache partition, then go into advanced and wipe dalvik cache, then reboot.
and/or
2. Do a fix_permissions. There are a few ways to do this. 1) In Terminal Emulator enter "su" then enter "fix_permissions" (minus quotes) 2) Run Gscript and load and run the fix permissions script. 3) Run ROM Manager and use the fix permissions feature (this one does not work on all roms though)
Still no go. Rebooted after fixing permissions and still get FC.\
Wiping cache had no affect either. Worked fine in CM6 but CM has too many bugs.
