Help MMS not working-Message Not Downloaded Transient Failure
knietert
I have an HTC One S. It was a T-Mobile phone and I am using it on NET10's network. I entered the APN provided by NET10 but was unable to delete the T-Mobile APNs. Everything is working except the MMS. The tex comes through with the tab to download the picture and it says downloading. The picture never appears and then the tab goes back to download. I get an error message that states Message Not Downloaded Transient Failure. Any suggestions?
I'm bumping your thread as well as extending a welcome to you. Best of luck and thanks for using these forums. I hope one of our helpful members has some insight into your problem.
This is most likely a ROM bug ...is it the branded ROM that T-Mobile put on it ?
...i know that it's network free/unlocked/sim free but the ROM part is different !
1st Try a factory reset;
2nd If you have the Branded ROM [check under settings>device info>software] try rooting and install other ROM !
In response to RAZVAN06 on 2/21/13. I had tried that after contacting HTC. I found the solution. Once I changed the APN type to default,mms,supl the messages poured in. Thanks for your suggestions though.
