Root MMS on dirty unicorn?
Erik-_-Chavez
What are the steps to get the MMS working on the stock MMS apk it give you. When I flash the MMS fix it gives me the old 4.1.2 MMS apk. How do I keep the new one. Can someone give me steps?
You need to manually add apn.
It does not always work, for me anyways.
Open voice dialer
Say 'open apn'
Create a new apn with the vm settings.
I don't know all the settings, but you should be able to find them somewhere
can anyone post the voice dialer apk i always delete it since i dont use it and i cant pull it ffrom the rom my internet is too slow right now to download a rom.
