MMS (photo And video) for me are not sending out or they take 1 day to take off is that a android bug or its our device anyone had this issue?
That's strange sounds like a network issue
I had this issue with t-mobile version using videotron and now with at&t version using rogers. Can you try to send an mms if it works great for you
What is happening first and see if we can fix it
I take a picture in gallery then hit send through sms then hit send and now it say : sending... forever
Ok what are your settings in mms and also are you using the stock messaging app?
the mms apn are automaticaly set by the sim card and Im using the stock message app
