mms...pic/sound
CatsTide
Android Expert
i get these cool little mms's with sound and pics and some with animation. i cannot save or forward these. if i choose to save them it saves them as separate files,sound and pic. i'm using handcent. is it a handcent problem,droid problem or am i doing something wrong?
when you want to forward, are you holding down the image on the screen? a popup menu should give you an option to forward.
and mine saves them as two files as well
I am using handscent also
