Help MMS problem?
so As of last night ((randomly and out of the blue)) my MMS has stopped working. I can receive perfectly fine, but when trying to send, i just get the little mail icon with the green arrow. I use Gosms, and I tried using the stock messaging app and its doing the same crap. Are there any known issues as of right now with the network or something? are there any fixes?
thanks!!
I had nothing but problems with gosms. I switched to handcent and it works much better for me.
this is the first problem I ever had with gosms, but it's a major one!
I just love the customization.
Have you tried Handcent? It has ALL of the customizations that GoSMS has, except it actually works :p
I suggest you give it a try if you haven't.
