turbohobbit
I seem to be having a problem sending MMS's from my phone. Basically, I take a picture, "share it" via Handcent, Handcent reduces the size of the piccy in order to allow it to be sent as an MMS, and off we go. But then when I try and send the message it takes ages to try and do it, then gives up as a bad job and the message never goes. I don't think this is a problem with Handcent as the stock SMS app also had the same issue. And this happens regardless of whether I have GRPS, 3G or H signal. Similarly when I receive an MMS from someone it either takes ages to download (I hit the download button in the received message, often multiple times after multiple failures) - by which I mean hours - or nothing turns up at all.
I was just wondering if anyone had encountered this and what can be done to resolve it. It's been going on for ages now - pretty much since I've had the phone - and no amount of ROM and radio changes have sorted the issue. Or is it just that MMS sending and delivery is an inherently flaky process?
