Help MMS/SMS Question
shortarc
Sorry to have so many questions but there are a lot of things on this phone I'm having trouble figuring out.
Is there a place to view sent MMS/SMS messages? I have looked all over and can't find any?
Also is there a way to separate Incoming, outgoing, and missed calls as to delete just outgoing without deleting all calls? Haven't found that one either.
Thanks.
For your first question... The sent and receive messages should be in your message app. If that's what you're talking about. Or are you talking about where on your phone your messages are stored even after deleting them?
For your second question... In call log press menu - call history - menu - view and select which option you want and delete.
Thanks. No I'm talking about where they are after they have been sent not deleted, can't find them.
On the deleting recent calls. I can go through the menus and select received calls out of the pop up box and not select any of the others but when I hit delete it deletes all of them. Probably something I'm not seeing.
