bamhm182
Has anyone else noticed that MMS takes FOREVER to send on their phone? It seemed to work well when I first got the phone, but now it doesn't work (nearly) at all. I'll try and send an MMS, then check on it like 30 minutes later and it still hasn't sent.
One thing that I have noticed that helps is to disable Wifi. At the time of this posting, I remembered that I have 3G disabled when I have Wifi on. Does the MMS only work over 3G/4G? Maybe I'll figure out how to make an exception to turning the 3G off when I'm trying to send an MMS, or just do it manually, and see if that helps.
