Help MMS where does it download too?
boxroid
So I'm pressing the download button that comes with MMS, I can see the data downloading icon, but then nothing happens, where did the download go to? Is there a folder with downloads or something?
thanks all
depends whats being downloaded, for example if its a picture it would most likely be accessible from your gallery.
It might mean it is downloading/opening in your message, thats what i`ve found.....If you want to save a mms picture keep your finger on it for a few seconds and a menu will appear asking if you want to save it....It should create a folder in your gallery, i think it`s called "Download".....I changed the name of mine a while ago so unsure of the name.....
