S shep938 Newbie Jul 21, 2012 #1 i have a lot of books in MOBIfile on my computer. will they work on the nexus 7...and if they do, what folder should i put them in
Atma Extreme Android User Jul 21, 2012 #2 Download the Kindle app. Then copy your Mobi files to the Kindle folder. If you can't find the app after you install, reboot your Nexus. That's what I had to do for some reason.
Xyro 4 8 15 16 23 42 Moderator Jul 21, 2012 #3 Atmazzz said: Download the Kindle app. Then copy your Mobi files to the Kindle folder. If you can't find the app after you install, reboot your Nexus. That's what I had to do for some reason. Click to expand... Rebooting triggers a scan for media files, that's why it works.
