Root Mobile data help..
OrKo
Android Expert
When I'm at home I'm always running off my wifi, I've noticed that recently when I'm at home while I'm on the wifi spot the Connect stays connected to the 4G service as well like it's running both. Is this normal? The only way I've seen to turn it off is in settings > wireless & networks > mobile network > data enabled unchecked, but then when I turn my wifi off I get no 4G. So my question is how do I or if I can stop the phone from running 4G while I'm running my wifi?
I have the same thing to man this phone has all sorts of bug's
Sent from my LG-MS840 using Tapatalk 2 Beta-5
Also the gps notification will pop up and stay on even though the gps is turned off. Turning it on then off will make the icon go away. I just did a factory reset (rooted no/cwm) and that straightened it out, but if it happens again I'd still like to know how to fix that w/o having to do another hard reset.
Also note that while the 4G and wifi are both on the way they were I was unable to surf using wifi, the 4G was doing all the work and sometimes wouldn't let me connect until I turned the wifi off.
