It's there a way to restore the Mobil data button after the update? I used to turn off all data at night so emails would not wake me up while on the night stand.
There was a mobile data button on the notification panel of 4.2.2. It's gone on 4.3.
More cumbersome, but settings/more networks/mobile networks/ has a check box beside mobile data so you can verify it's on.
Actually, no. I'm not always in 4G area where I am so often times I won't see the notification as you state but if I drill down into the settings Data is on/selected. So I can't trust that way of knowing if data is on or not..Isn't the notification area sufficient with either the mobile data icon or the wifi icon showing? My GS4 shows 4g/LTE for mobile data or the wifi icon, depending on whether I'm in a wifi area or not and connected to wifi.
