Help Mobile Data Not Working
Metamence
I'm using the latest version of Tickerguy's CM7 with JuiceDefender.
I have JuiceDefender enabled with all the default settings (balanced and etc).
This morning, my mobile network was working fine and I loaded a few webpages.
Later on, I found out that I have no connection.
It says that I have 3 bars of signal strength and my Mobile network state is Disconnected.
I've tried reinstalling JuiceDefender and rebooting my phone, both of which haven't worked.
Any help? I don't want to go back to an earlier back up, however I'll do so if I must. I really need the 3G for tethering my laptop and on the go use, but I use Wi-Fi at home.
Edit: Going to Settings>Wireless and networks> Mobile Networks>Data Enabled works... Doh!
Have you tried it with Juice Defender disabled or uninstalled? I had a problem at first with JD on my Triumph with the stock ROM. I forget now, but I played around in the settings and got it to quit killing the Data for good when it cut off. I think there's a force radio fix in the settings or something like that.
I switched to MiUI and haven't loaded JD. I am having pretty good battery life without it.
i could not connect to data either ...and i had juice
i returned my phone because of it. I wonder if that was the problem? hmmm
