Help Mobile data stopped working
morisone
Hello guys
since wednsday I can't use my mobile internet.
I checked my APN settings and I didn't find anything which could make any problem. I just use Quick Settings and I used to switch sometimes between on/off in the mobile data. I don't know what's the problem...
I even reset my phone and reinstall everything but the mobile internet doesn't work to me. when I tried to enable my mobile data on Quick Settings, for a second the 3G Icon appears on the top of the screen and then it disappears. it looks like something stopps my mobile internet working.
someone can help me? :confused:
I need your help as soon as possible because I won't be at home for 2 weeks.
Thanks
Hello guys
Thanks
I had a similar problem with this customer yesterday. We backed up all her stuff including her contacts, pulled out the SD card to make sure and did a hard rest to factory default setting's. It worked right away, it's a little extreme but if that don't work then it could be a hardware issue, or the carrier itself.
I also did it and it didn't work to me... except that I installed 2 ROMS and nothing was changed ... I don't know what to do ... something on my device stopps the mobile data working and I can't be able to guess what makes it stopps.. tomorrow I won't be at home for 2 weeks and I need the mobile internet to work :(
Hope someone would be the rescuer!
The next step I would try is flashing the stock SBF file...
Hope you are familiar with this procedure using RSDL.
You will lose all your settings of course but if nothing else is working its worth a try.
I don't know what you mean... I did something with SBF file on RSDL...
I installed an Italian ROM and nothing was changed and I installed another ROM and nothing happened.
I'm almost sure that the problem is maybe on the settings of the mobile data and I have to change something which has been disrupted since Wednesday.. I also use APNdroid .. and when I click on 3G/EDGE/GPRS botton the 3G icon apperas on the top of the screen and then it's gone.
I'm hopeless :confused: what should I do??
You should be using the original SBF file for your area. I'm in Canada and on Telus so I use the original Telus 3.10 to stock my Milestone and update to 3.11 and so on from there. Works every time, I hope you can get this resolved! :cool:
If it is a carrier issue there is nothing we can do. Wait tille Monday and talk to them first.
Once again I agree, no point in flashing if it's a carrier problem. If you want to try in the mean time while you wait for the next two days by all means.
