Root Mobile data won't work on ANY rom
sabresfan
Member
not sure what's going on, if it's on my end or virgins. it hasn't worked for 3-4 weeks. I tied re flashing myraido and got nothing. do I have to re flash the stock and do some of those dialer codes? it would be nice to have it back
Yup, usually you have to go back to a Stock ROM and update profile. One time though mine got so screwed up I had to be on the phone all day with VM trying to reactivate and program it.
Go back to a stock ROM with working a epst.apk(to activate your phone), then call virgin mobile using a different phone. Before calling them, you can try updating profile, it takes a veeeeeeeeeeerry long time though, so you might as well call virgin mobile one time. I always keep a sense ROM flash able zip on my SD card, I keep midnight ROM 112 to be exact(that version was the last working version on midnight ROM sense before epst.APK became broken, which in turn mean you can't activate your phone on that ROM.)
