On the Verizon version, it is under:
SETTINGS
MORE SETTINGS
MOBILE HOTSPOT
...having said that, mine is greyed out. Maybe I need to have it out of Wi-Fi mode, but I'm out of the country right now. Is this setting working for anyone else on Verizon?
I'm back in the country and I just tried it. It seem to set up okay, but then I get notification telling me that this service requires a subscription to Verizon Mobile Hotspot or Mobile Broadband Connect and it wants me to subscribe for another $20/mth.On the Verizon version, it is under:
SETTINGS
MORE SETTINGS
MOBILE HOTSPOT
Verizon made me give up my my unlimited plan when I got the Galaxy Note 3. I wish that I could have kept it just for "peace of mind". I never get close to going over. Thanks for the info.Unless you're rooted, I believe the majority, if not all the US carriers charge a monthly fee to use the hotspot, no matter what your data plan is. I'm on Verizon, been with them for 7 years, unlimited data and the only way I get it to work is rooted and running a custom ROM. Hotspot and removing bloatware are the only reasons I root my phone. And I'll continue to root every Verizon phone I get![]()
This is a little confusing. I'm stock on VZ, 6GB plan. No hotspot upcharge, at least not separately identified as such on the bill. My N3 works perfectly as a hotspot for my Tab 3 tablet: here's my sign-on sequence:
On N3, Wi-Fi antenna off, Mobile antenna on
On N3, Settings - More Settings - - turn Mobile Hotspot on
On Tab 3 Settings Wi-Fi page, find the SM-N900V hotspot and select. The first time I connected I had to enter the password provided by the N3.
Once connected, my tablet shows as a 'Connected Device' on the N3 Mobile Hotspot page, and everything works fine. I'm puzzled as to why you're having problems.
Because you don't have unlimited the the FCC requires that they allow hotspot.
When you have unlimited the carrier can and typically does charge for it.
I have a Verizon 6 GB data plan (I gave up my unlimited a couple weeks ago to get a subsidized price on the upgrade to a Note 3).
I just tried it on my Note 3 and when I turn the Mobile Hotspot on in the N3 settings, a message pops up that says it is checking subscription status; then it pops up a message that says a subscription is required and I should contact Verizon.
If you are sure you're right about the FCC requiring carriers to allow hotspot when the data plan is limited, I think I will contact Verizon about this.
I am on Verizon and using a non-rooted note 3, the hotspot works fine with no extra charges. I do get the pop up thats says, checking subscription, but it always connects after a few seconds. This feature also worked on the note 2....so I've been using it almost 2 years.
Because it's not illegal, and they can make more money that way (unless you use a 3rd party app).I don't know why my voice plan should be a factor in how I use my data plan
Any time you wonder why a business does something that seems screwy, think money first. If that doesn't explain it, think money. It's all about money.
