ShortGamma
Hello,
I am a Vodafone customer and have managed to use both voice/data roaming when abroad without a problem. However, in Japan the data roaming just doesn't work, though voice works without a problem.
If the handset is configured to automatically select the carrier it selects NTT Docomo.
However, in the network config menu it says that mobile internet is disabled due to incorrect APN settings.
Can someone tell me what these should be, and how do I chage them? I have an unlocked handset.
Thank you.
PS - Alternatively I can also use Softbank in case anyone has those APN settings handy.
Thank you.
Thank you.
Thank you.
